RCU Forums - View Single Post - Micro-iceberg dual-drive setup
Old 04-09-2008 | 07:22 AM
Stokes's Avatar
Stokes
Default RE: Micro-iceberg dual-drive setup
SV27...your curiosity will be satisfied....it was more a matter of not wanting to undo what others did to the boat before i bought it. Apparently the seller had read this article on this German boating magazine, where the iceberg was set-up with 2 outrunners, so i decided to play along with the madness....should be running 2x2s lipos (one for each motor/ESC)...just bought the props. Will run 2x 33mm graupner ks (on the magazine - which the seller kindly included in the sale, the boat is said to reach 50+ km/h with 33mm props, and even with 36mm, the article said it should go even faster without the motors getting warm - though this still needs to be verified by yours truly).
Fiend - what was that you're saying about the servo? didn't quite get what you meant....
