RCU Forums - View Single Post - Refueling Valve?
Old 04-09-2008 | 12:47 PM
YUKONFLYR's Avatar
YUKONFLYR
Default RE: Refueling Valve?
When I first started this hobby, I used the fueling valves. Robart makes one that is streamlined, that flips up............
Then I went to a third line with a plug.......
After that I now only use two lines, one for the engine fuel supply and one vent. I pull the line prior to the filter and use that as the fill line. Less complicated, however for my fully cowled mustang, It still has the robart filler.
