RCU Forums - View Single Post - CG and Lateral Balancing
Old 04-09-2008 | 03:22 PM
yetti831
Default RE: CG and Lateral Balancing
Great information! Can you please explain why a nose heavy plane will climb, and why a tail heavy plane will dive?
P.S. I found this information:
"If your bird, instead, steepens the dive, you are tail-heavy. This is for the same reason as why it climbs when nose-heavy: you're flying faster than your trim-speed, so your elevons exert more up-force, causing your nose to pitch downward. The elevons were literally "propping up" the tail of the aircraft at cruising speed." Source: http://barnson.org/node/1072
