Ok got it out and all greased
I went to the hobby shop,they didnt have speed grease,but some other blue stuff in a tube made by proboat,it says its for flex shafts so it should be all good!
I feel stupid,for soem reason I thought it came out from inside the boat
How often to you lube the bearings in the motor? and for that im going to need that screw out aint I?
Why im here,do you guys pack anything in the hole where the antenna comes out of the hatch?,the other day "first run" when I flipped it water must have got in through that hole,but all and all it wasnt much,for it floating upside down for 15 minutes and me puching it all the way back in there was only about a cup of water I thought it would be much worse.
