RCU Forums - View Single Post - CA hinges VS pinned hinges
Old 04-10-2008 | 01:41 PM
Missileman's Avatar
Missileman
Default RE: CA hinges VS pinned hinges
ORIGINAL: opjose
Ok, someone correct me if I have it wrong..
I see "pinned hinges" being used where people mean "pin hinges" or "hinge pins".
"Pinned hinges" can include CA hinges, where someone has elected to insert a metal or wooden "pin" through the wood to hold the material in place.
Often toothpics are used.
"Pin hinges" or "hinge points", are dowl like ( usually plasitic ) hinges that are inserted into holes drilled into the control surface and wing.
The two are NOT the same thing.
I prefer PIN hinges, over PINNED hinges.
I assumed (I know ) he was refering to something like this:
http://www3.towerhobbies.com/cgi-bin...&I=LXD941&P=ML
Or this:
http://www3.towerhobbies.com/cgi-bin...&I=LXD944&P=ML
both of which pivot on a pin.
Although you are correct, a pinned hinge does make me think any hinge that is installed and then pinned to keep it from ever coming loose.
