 CA hinges VS pinned hinges >
Old 04-10-2008 | 09:19 PM
Default RE: CA hinges VS pinned hinges
ORIGINAL: opjose
ORIGINAL: 2slow2matter
I didn't even know that CA hinges were actually a plastic piece with fiber around them. The fiber part that is on the outside (that actually absorbs the glue and bonds with the wood) was still glued securely to the wood on the TE of the wing. The smooth plastic inside part of the hinge was sticking out of the aileron.
That is exactly what happened to me on the elevator and rudder of a plane I purchased second hand.
I thought that the builder had installed poor plastic hinges, but now that I think of it, it is exactly as you describe...
The "inner" part of the CA hinge was still in the control surface, shiny and smooth.
The fibers were left in the elevator and rudder along with the CA...
The plane is no more.
Same thing happened to me with gp ca hinges. Rudder ripped out when it hit on a dead stick landing. I now use radio south and have no problems.
Old 04-10-2008 | 11:17 PM
sportrider_fz6's Avatar
I guess I was confused about the meaning of "pinned hinges" but it's clear now. I installed the ailerons in the wing, following the ca hinge link, it is easier then I thought it would be. they seem to have good movment and feel secure. thanks again for the help!!!
