RCU Forums - View Single Post - Engine mounting problem.
Old 04-10-2008 | 05:31 PM
Insanemoondoggie's Avatar
Insanemoondoggie
Default RE: Engine mounting problem.
Bolt the engine to the mounts, then loosen the firewall mounting screws and rotate the mount as far as it will go in the slots , tighten firewall bolts. . I think you`ll find your clearance will improve enough to clear your fuse.
