magnum xl 80 rfs
this engine is not getting fuel. the tank, line and pickup clunk are ok. i did take off the carb, cleaned and put it back. the idle mixture is loose, but plan to put a piece of tubing on it. still, it should pick up fuel. was used on a hog bipe several years ago, but has not been run since. turns good and has good compression. any help would be appreciated.
