magnum xl 80 rfs
IN
magnum xl 80 rfs
this engine is not getting fuel. the tank, line and pickup clunk are ok. i did take off the carb, cleaned and put it back. the idle mixture is loose, but plan to put a piece of tubing on it. still, it should pick up fuel. was used on a hog bipe several years ago, but has not been run since. turns good and has good compression. any help would be appreciated.
My Feedback: (35)
MN
RE: magnum xl 80 rfs
ORIGINAL: ggale
Try spinning the engine with an electric starter and plug the muffler for a second or two. You should see some fuel being drawn.
If it doesn`t draw fuel and fires up with the above method try adjusting the LOW END needle half a turn out (counter clockwise) to begin with. This should help the matter.
IN
thanks, youve given me some ideas. well, today i pulled out the needle valve and attempted to clean it. i believe it has some castor goo, possibly in the spray bar. now it draws fuel to the carb, but not up the intake. any ideas on the best way to clean this? so far i have just used penetrating oil which has worked before on 2 strokes. thanks for any additional advise.
