melted wing
Hi,
I don't think you need worry the effect on the handling will be very small.
If you are concerned you could restore the tip by covering over the sunken area with some sticky tape. For a less obvious repair, fill the area with lightweight filler and repaint, you may need to add a little weight to the other wing tip to re balance.
Simon.
