RCU Forums - View Single Post - Finished my Avistar, Few questions and abnormalities...perhaps normal?
Old 04-11-2008 | 11:16 AM
carrellh's Avatar
carrellh
Default RE: Finished my Avistar, Few questions and abnormalities...perhaps normal?
ORIGINAL: n19htmare
1) "Put foam between the wing and saddle if havn't done so."
I know what the wing is, but what's the saddle? Is that where the wing sits on the fuse? I should have foam to cushion the wing?
The saddle is where the wing sits. I've never put foam there but some people do. They usually use thin foam tape that is probably some sort of weather stripping that is repackaged in small quantities to be sold at hobby shops.
ORIGINAL: n19htmare
2) The switch has three wires. two on one side and one on the other side. on the two wire side, there is a female and a male plug... how should it be wired?
The wire on the 'one wire' side plugs into the receiver. On the other side the male connector is for charging and the female connector goes to the battery.
