ORIGINAL: carrellh
The wire on the 'one wire' side plugs into the receiver. On the other side the male connector is for charging and the female connector goes to the battery.
Hmmm I tried that and the Receiver wouldn't get powered when I flipped the switch to on... Then I pluged the other wire into the receiver (the side with two wires) and then the switch works. it turns the receiver on and off but then only wire that's left is the lonely one on one side. That when plugged in to the charger just turns the receiver lights on faintly (as if it's charging the receiver, UNLESS it's charging the battery THROUGH the receiver)...
I get the feeling the switch I bought is toast
