F-22 Raptor Hangar 9 - Installing Flaps
Newbie here - I posted the same question on the ARF/RTF section then realized that I should probably post it here in the NEWBIE section, duh! Ok, question:
I'm installing flaps on the F-22 Raptor (PTS) from Hangar 9 and I'm having issues. The inst. tell you to "just install them" and when I did, I get reverse throws (one flap goes UP, the other goes DOWN). I'm using Futuaba servos and a Y-adaptor but what gives?! Why are they going reverse? I could turn one of the servos around (physically) but this would cause me to modify the servo arm and the flap installation area under the wing. Much more work then the manual makes it out to be. I don't think this is what Hangar 9 intended.
What am I doing wrong?
