Roo Wing Attachment???
Ok guys...
Here is a simple solution that has work perfectly for me....
Take an allen wrench an cut the "L" off so you have a straight hex shaft that fits inside the head of an appropriate allen bolt your using to bolt the wing on. Silver solder the hex shaft into the head of the bolt, make sure it is straight. You can now install and tighten your wing bolt from the wheel well. A simple 1/4" drive socket wrench with the appropriate size socket is used to tighten the bolt by sliding it onto the hex shaft which will be at about the same location as your wheel (but above it). If you have any questions I can supply pictures....
Todd
