RCU Forums - View Single Post - Confused about Ball Links for push rods
Old 04-12-2008 | 02:34 PM
Rodney
Default RE: Confused about Ball Links for push rods
IMHO the comment saying ball links pop of easily is grossly in error. They are probably one of the most reliable ways to connect to a horn or servo arm. It is almost impossible for one to disconnect unless a very strong force at right angles to the normal stess is applied, even then you may have a hard time popping one off. The ball joint is supperior to clevisis, Z-bends and most other type connections, especially if you do not want any slop in the system.
