Hmmmm...don't own a Jet Central turbine and all you can do is rag them? Wow...that really says it all...and more.
Beave
ORIGINAL: littlepiston
service.
Littlepiston...the reason your posts usually get removed I would bet is because all you ever do is post harsh negative things about Eric and Jet Central. Do you even own a Jet Central engine?
Beave
HEHEHEH like i said!!! you are right i dont own a JC turbine for this same reason.
its not being negative its the truth!! CAN YOU HANDLE THE TRUTH??........................................... .......YOU CAN'T HANDLE THE TRUTH!!!!
