RE: Composite-ARF Integral, kinda build thread
hello
I'm soon ready to fly my Integral.
paint is done and starting to get the engine in !
I have tilted the engine (YS 170) over ca 10 degreed to avoid the manifold to hit the belly pan , it seems maybe this will be enough there but one thing i didnt notice is that the pump probably will hit the b.pan when running have ca 5mm clearence here.....
the Engine is mounted on the YS M mount on some alu pieces.
my question is ......
Have you guys tilited your engines over ....how much does the engine moves on this YS mount(havent use one yet)..and have you made holes in the b.pan to manifold and\or pump...and which type manifold you use , i have the hattori with low rise #823.
some pics off the install and b.pan holes whould be nice!
I have just test run the 170 in my Goodshot and must say it was pretty hard to start ...my starter that turns the 160 with no prob. could not start it .... maybe i have to be hard to it and give it some more cells to rise the voltage some, but engine runs nice !
