RCU Forums - View Single Post - JR Tx battery problem
Old 04-13-2008 | 10:51 AM
PR3
Default JR Tx battery problem
The battery in my JR 7202 semms to be dead. I went to charge it on my Accu-Cycle and I got the message to check connections. Those were fine, checked the transmitter and found the power switch was on (thanks to my two year old) but the display was blank. Again no luck with the Accu-Cycle. Tried the factory charger and the charge LED does not light up. Put a volt meter on the battery and I have about 11v. I put the meter on the transmitter battery pins with the factory charger on and get 1 to 3 volts. The battery is a Ni-MH 1500mAh 9.6v. Did the battery drain to a point that I can't charge it? Or do I have another problem. Any help would great.
