RE: Composite-ARF Integral, kinda build thread
Hi Rune,
... Still waiting for the spring here, at least if you need to drive to the field ...The last piece of the road is still too soft. I guess beginning of next month will do.
Sending some pics of my installation. The Equipment used is slightly different than yours though .
ARA 140 mount , 822 header , original nose ring.
The engine is mounted "straight-up", but i needed to adjust the right-thrust additional 2-deg ( total of 4-deg). Working just fine; no rubbing or slamming in the engine-compartment.
Kjell Olav
