RE: Yellow F-4 setup
Here you go, I''m just about to start mine.
CG - 8"-8 1/4" behind the leading edge of the wing at the root balanced with full fuel tanks.
Travels:
Ailerons 1/2" up, 1/2" down high rate
5/16" up, 5/16" down low rate
Elevators 1 3/8" up, 1 3/8" down high rate
1 1/8" up, 1 1/8" down low rate
Elevator is at neutral when the leading edge is 3/8" above the angling panel line on the left side of the fuselage.
Rudder 1 1/2" left, 1 1/2" right
Dan
