Yellow F-4 setup
VA
Need throws and CG for my Yellow F-4 ducted fan. This is the factory built jet with ailerons and no flaps. Also, what is the elevator setting at neutral?
JH
JH
Here you go, I''m just about to start mine.
CG - 8"-8 1/4" behind the leading edge of the wing at the root balanced with full fuel tanks.
Travels:
Ailerons 1/2" up, 1/2" down high rate
5/16" up, 5/16" down low rate
Elevators 1 3/8" up, 1 3/8" down high rate
1 1/8" up, 1 1/8" down low rate
Elevator is at neutral when the leading edge is 3/8" above the angling panel line on the left side of the fuselage.
Rudder 1 1/2" left, 1 1/2" right
Dan
Travels:
Dan
