RCU Forums - View Single Post - Sig Sukoi: What are balance and throw specs
Old 05-01-2003 | 09:33 PM
GoeKeli's Avatar
GoeKeli
My Feedback: (18)
Default Sig Sukoi: What are balance and throw specs
SPECS: Wingspan: 76.75" (3019mm) Wing Area: 1152 sq in (74.30 sq dm) Weight: 13 - 14 lb (58.9 - 63.5kg) Wing Loading: 26 oz/sq ft (79.34 g/sq dm) Length: 66.9" (1699mm) Airfoil: Fully-symmetrical, low wing. Center of Gravity: 4.75" (121mm) Back from the wing's leading edge Control Throws- Low Rate High Rate Ailerons: Up & Down 7/8" (23mm) 1-1/8" (28mm) Elevator: Up & Down 1" (26mm) 1-1/2" (38mm) Rudder: Right & Left 2-1/4" (57mm) 2-1/4" (57mm)
HTH,
Joe
