Sig Sukoi: What are balance and throw specs
CA
Hello Guys
I just received my NEW and IMPROVED wing for my SUKOI. The problem now is that I misplace the manual. Don't need the manual to build but having the proper balance point may help a LITTLE? The throw specs won't hurt as well.
Any help would be appreciated
I've waited a long time to assemble and fly. I think guessing the CG would be as dumb as loosing the manual
My Feedback: (18)
SPECS: Wingspan: 76.75" (3019mm) Wing Area: 1152 sq in (74.30 sq dm) Weight: 13 - 14 lb (58.9 - 63.5kg) Wing Loading: 26 oz/sq ft (79.34 g/sq dm) Length: 66.9" (1699mm) Airfoil: Fully-symmetrical, low wing. Center of Gravity: 4.75" (121mm) Back from the wing's leading edge Control Throws- Low Rate High Rate Ailerons: Up & Down 7/8" (23mm) 1-1/8" (28mm) Elevator: Up & Down 1" (26mm) 1-1/2" (38mm) Rudder: Right & Left 2-1/4" (57mm) 2-1/4" (57mm)
HTH,
Joe
HTH,
Joe
