RCU Forums - View Single Post - Pc 9 By Seagull Models
Old 05-03-2003 | 09:43 PM
Lt. Dan
My Feedback: (21)
Default Pc 9 By Seagull Models
Originally posted by Slug
Salman,
I have the Seagull PC-9.
No problems putting it together and no problems with quality.
Nice touches are pilot and canopy pre installed and the flying surfaces are already attached and the hinges pinned. Flys very well even in quite windy conditions, mine has clocked up 50+ flights during the past couple of months. I am using a .45 2 stroke, that seems about right. With the control throws set with small movements would make a good 1st low wing model, but is capable of being thrown around plenty if you want.
The only negative thing I found was that the fuel tank supplied has only two outlets and with the engine cowled it's a bit of a pain getting to the carb to disconnect for filling/draining, in the end I fitted a joiner in the fuel tubing away from the carb so I could get to it at a more convenient point, If building another I would replace the tank with a three outlet type.
Hope this helps.
Simon.
I saw one of these flying at our field today and I'm going to get one, very sweet on a .56 Saito.
BTW, that's what they make remote fueling valves for!!!
