RCU Forums - View Single Post - Diffs locked or not???
Old 04-15-2008 | 04:07 PM
drevil
Default RE: Diffs locked or not???
If you''re racing you definitely don''t want to lock the rear diff. Some people do run lock diffs (spool) in the front on 4wds though. For drifting some people do lock a diff and others dont. I definitely wouldn't lock the diff on the F1 unless you're looking to make a drag car. Locking the diff will make it want to spin around corners.
As for when buying a used R/C I wouldn''t buy one with a locked diff unless it was a rock crawler. Most people use jb weld to lock the diff which is irreversible.
BTW Has anyone noticed that when you use an apostrophe in RCU it adds a second one right next to it which makes it look like you used quotation marks by mistake. For a few days I thought it was my keyboard doing this but then I noticed others having the same problem.
