RE: How should servos be installed?
Most seem to follow the directions included with the radios for servo mounting, but I often see that people don''t install the servo correctly in the airframe. Since the servo's function is to push and pull, you need to align the long axis of the servo with the direction it is applying force. Otherwise, the servo tends to rock back and forth and the precision control is lost.
