RE: In need of some repair advice.
[img][/img][img][/img] Here are the pics you asked for. The rib with the top chipped out of it is where the impact was centered. the balsa across the top was shattered 2 inches to both sides. It had also broken out the brace behind it on the (root i believe) and it was in several pieces. All I have removed is the section across the leading edge. everything else is as it was when I removed the covering.
