RCU Forums - View Single Post - GX31 carb
Thread: GX31 carb
Old 04-16-2008 | 12:51 PM
av8tor1977's Avatar
av8tor1977
Default RE: GX31 carb
So far in testing mine is working ok. It is a Zama carb with a 10mm venturi. I added a spring to the fuel pump and used an external pulse line tapped into the intake manifold. (No problems with oil in the pulse line that way.) I was considering trying that WYK-16 carb that BCMA engines sells however just to see if it worked any better, so it would be great to see this cleared up as to whether it has both adjustments or not...
Good luck,
AV8TOR
