RCU Forums - View Single Post - Mojo Moass build thread
Old 04-16-2008 | 07:39 PM
custards1
Default RE: Mojo Moass build thread
Well progress lately has been a little slow. The main build is done now, have used lots of filler to fix up my crap building . I finaly got permission from the other half to spend the last of the money for it on hard where. so here is a pic of what im going to use its 4-40 dubro ball links with a left/right control horn then going into a carbon rod, feels real nice and smooth cant wait to get them in use. The idea is to mock it up on some of the bigger planes gear with lighter weight stuff to try and achieve the same result, no twisting or slop and a nice rock solid link. I have never used anything like this before so im pretty happy so far. I also brought the battery witch is a 1500ma NicMa i still cant get over how small the dam thing is, i have only ever use nicad so its a nice change for this plane. I also go a switch i know is a bit big but i wanted one with a charge jack on it so i dont have to take the hatch off ever time i need to charge or check the battery. At the moment i am waiting on the hinges to arrive from tower so i can set it up and test for balance before i cover as from what i read its much easier to move the servos now.im going to use standard dubro pined hinges as they seem to have the least friction and best movements when setup right
ID:	930931   Click image for larger version
