As it is, Ive once again looked into what all is needed to "convert" the normal pullstart to the combo system
I use the word "convert" since you cant just slap the new pull/spin start on the engine and call it good... you have to buy more parts to make everything fit correctly [:@]
Anywho, If you have the stock Mach.26/ 26SS or the Mach427 you will need to buy
ALL these parts, NONE of the stock parts will fit this new "application"[:-]
LOSR1037 pullstart ( combo system )
LOSR1041 Backplate
LOSR1042 Start Shaft and spring
LOSR1043 Oneway bearing
And now to the next task at hand
