RE: Infinity Diff Gear
ok when you install the gear back on the motor's gear bell must mesh correctly. When you install the motor you need to position correct so that when you roll on the ground it should be running freely. The you lock the engine back in place and then try to roll it again and you can feel it and make sure there is no binding at all. If you can do that you gear will last.
Andy
