Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Infinity Diff Gear
Old 04-17-2008 | 09:27 AM
Default Infinity Diff Gear
Hey all. a couple of days ago i bought a new main diff gear for my Infinity witin 25 minutes the gear had worn away agen. (it worn away when the truck was sitting idle all of a sudden the engine screaming and it had worn away.) because i live in the uk i bought a couple of the gears this time. i was just woundering if any of you guys could help me. weather theres away to make the gears last just a bit longer than 25 mins. thanks all.
Old 04-17-2008 | 09:46 AM
Default RE: Infinity Diff Gear
ok when you install the gear back on the motor's gear bell must mesh correctly. When you install the motor you need to position correct so that when you roll on the ground it should be running freely. The you lock the engine back in place and then try to roll it again and you can feel it and make sure there is no binding at all. If you can do that you gear will last.
Andy
Old 04-17-2008 | 10:09 AM
Thanks Andy
