RCU Forums - View Single Post - OS .46SF- Re-Ringing
Old 04-18-2008 | 08:36 AM
on pipe's Avatar
on pipe
Default RE: OS .46SF- Re-Ringing
Mr Bigg, Either ring will work, Frank does top-notch work. I've used a number of his rings and they were perfect runners. Just "hone" with a piece of 400 wet/dry wrapped around your finger. Use some lube. (penetrant, etc.) Try to use a twisting motion to replicate the crosshatch marks of a hone. This is assuming the sleeve isn't TOO worn. Ross
