RCU Forums - View Single Post - Phase 3 EF - 16
Old 04-18-2008 | 08:26 PM
P. Richards's Avatar
P. Richards
Default RE: Phase 3 EF - 16
Phase 3 is the best foamie F-16 on the market it flies great slows
down for landing and does not tip stall.
I have flown a high powered version of a 90mm F-16
and the flight characteristics are the same. It is a good ducted fan
trainer and should give you months of enjoyment, if you leave
it stock and just go fly. The speed control works great and the
fan unit pushes the plane around at approximately 65 to 70 m.p.h.
in a diving high speed pass. I use the Thunder Power 2070mah 11.1 (3) cell packs
and the extreme V2 2200mah 11.1 (3)cell packs. good for approximately
5 minutes of flight using throttle management.
P. Richards aka SwatTeam
