RCU Forums - View Single Post - ingenuity
Thread: ingenuity
Old 04-19-2008 | 07:17 PM
Frank_514
Default RE: ingenuity
I'm working on a transportation case for my buggy! I want something that will include everything I need: “Portable Work Shop” and "Storage / Carrying Case” all in one. I used second hand material except for “fasteners” (pop-rivet/glue).
I will put tool box rail to make the car jack operate smooth and a rotary plate so I can rotate the buggy and I want to use a kind of Cleco system to hold the buggy on the plate for transportation and engine run! I will add a pipe to put the exhaust away, like real garage. The space on the 2 inch cover, I will put a black foam, carved to hold remote control, tools, spare parts and a bin area made with transparent plastic pills container. I will cover all the inside with black foam (if the buggy can fit in, I just made extension wheel hub and I put 2 double set of tires).
I build a compartment on the rear side of the box, between the wheel bins. I will probably use it like a battery pack area.
Still a lot of time to wait to finish the project. Finding the good thing to re-use is hard, but the harder is to get every tings before going to far!
“Measure twice cut once!”
I re-used garbage for the box and keep the money for the buggy!
See Yaa!
Frank_514
ID:	932825   Click image for larger version
ID:	932826   Click image for larger version
ID:	932827   Click image for larger version
ID:	932828   Click image for larger version
ID:	932829   Click image for larger version
ID:	932830   Click image for larger version
