RCU Forums - View Single Post - ingenuity
Thread: ingenuity
Old 04-19-2008 | 07:38 PM
Frank_514
Default RE: ingenuity
I used a used “BBQ meat” temp sensor (less than 6$ in big stores ) . I removed the temp probe from the stainless steel needle gauge. I put a heat shrink over the probe and installed it at the hotter spot on the engine body In a loop shape in the cooling fins of the engine. I program the gauge to 150C so it start to beep as a warning. Its instant temp reading only but I can ride with or without it as required.
See Yaa!
Frank_514
ID:	932855   Click image for larger version
ID:	932856   Click image for larger version
