ORIGINAL: Villa
Are you an experienced R/C pilot? I usually use a 2 bladed 10X7 prop on a 46 engine. Is that 3 bladed prop recommended for that engine?
I have a couple of years flying. I normally fly a 11 X 6 on the .46. The 10 X 6 three blade should be ok, if not I will change props to a 10 X 7 or 11 X 6.
I will not be the one to maiden the plane, I am not good enough for that yet.
