 Question on Maiden flights? >
Old 04-20-2008 | 09:26 AM
Default Question on Maiden flights?
I have a nice little .40 GP Corsair that is ready to fly for the first time today. The plane is in great shape, I built it three years ago, and have hung it in my Son's room since then. I am now feeling ready to try it in the air. I have a Magnum 46 driving a 10 X 7 three bladed prop, the plane really looks good.
I want to fly it today! Here is my question, should I take a photo of it before the maiden flight or after?
I am very nervous and excited about flying the plane - any tips on flying a low wing war bird for the first time?
Old 04-20-2008 | 09:40 AM
Default RE: Question on Maiden flights?
I always get the picture prior to first flight because you just never know.
Best of luck.
Rufcut
Old 04-20-2008 | 09:45 AM
Villa's Avatar
Are you an experienced R/C pilot? I usually use a 2 bladed 10X7 prop on a 46 engine. Is that 3 bladed prop recommended for that engine?
Old 04-20-2008 | 09:53 AM
ORIGINAL: Villa
I have a couple of years flying. I normally fly a 11 X 6 on the .46. The 10 X 6 three blade should be ok, if not I will change props to a 10 X 7 or 11 X 6.
I will not be the one to maiden the plane, I am not good enough for that yet.
Old 04-20-2008 | 09:59 AM
11X6 2 blade or 10X7 3 blade should be fine on a strong 46.
Take pictures at the field before you fly it.
I'm assuming you've mastered your trainer.
Check all control surfaces, make sure NOTHING is reversed.
Range check the radioboth with the engine off and running (have someone stand "on the tail" to do your range check with the engine running).
Give all control surfaces a tug to make sure the hinges are still stuck good.
Make sure all servo screws are tight, and make sure you have a "safety" (either clips or fuel tubing) installed at every control horn.
I recommend you stand on the runway, behind the plane for the first takeoff. Tail draggers act differently than trainers, and it will pull left quite a bit until the tail comes up.
Don't yank it off the ground, let it fly itself up.
Keep the gear down. Never raise the landing gear on a maiden. Just trim, fly, and landall within 6 or 7 minutes.
When landing, fly the plane all the way down.
Oh, and most importantly, check the CG one more time before leaving the house. Make sure it's balanced, and the batteries are still good.
Good luck.
Old 04-20-2008 | 12:04 PM
ORIGINAL: 2slow2matter
Why keep the gear down? I have maidened a few retract equiped planes and always retract the gear. It would be a little hard to trim properly with the gear down in the wind. Just wondering,
Old 04-20-2008 | 12:47 PM
My policy on retractable gear (and this comes from all of the experienced guys I've ever been associated with) is to NOT raise the gear during a maiden. Just one more thing that can go wrong. If the engine dies, you don't want to have to mess with the gear on a maiden dead stick. Also, if a gear gets stuck, the maiden landing is a bad time to deal with that. I just want to have all of the issues with the plane worked out before I throw that one in there. I want to know ALL of the characteristics that I can know before I deal with extra issues.
Sure, there may be some minor trim issues involved, but not more than maybe one or two clicks of elevator. The rest of the plane can be trimmed out easily with the gear down.
Some people want to play with all of the bells and whistles. To me, get it up, get it trimmed, make it stall a few mistakes high to see what it is going to do. Pull a loop to see if it will snap (again, very high). A couple of other housekeeping items, and get it back down in one piece. Go over everything with a fine tooth comb to make sure nothing loosened up. Re-fuel, and then start wringing it out.
Old 04-20-2008 | 02:15 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
I'm with 2slow on this one. I always leave the gear down on a maiden flight. Take the plane up and trim it out, then land the plane once you have it trimmed. Then, like 2slow said, go over the plane with a fine tooth comb. Check that everything is still tight and in proper working order. After all that is done the plane can go back up and retract the gear on this second flight.
Ken
Old 04-20-2008 | 05:13 PM
Thanks for all of your thoughts, I had the plane ready to go at the field, she was charged, fueled and I had a more experienced guy ready to take it into the air, but it was not to be, when I tried to start her up, the engine mount came loose, back to the shop for some repair work, maybe I will try again next week.
On the other hand I had a great day with my trainer, did some extended inverted flying for the first time, and snapped some sharp loops from the inverted position, I am really pushing my trainer to the limits right now, a bit worried that I will eventually fold the wings on it if I pull any more G's than I did today!
Old 04-20-2008 | 05:21 PM
Other than getting the engine mount fixed, I have done a very full preflight check on the plane, all servo screws are tight, every control throw has fuel tubing to lock down the arm, there are no retracts for me to worry about. I was going to let a much more experienced guy take the plane up for the first time, but yes my overall plan is to take it very slow, this is an untested plane, that I spent a lot of time building, I have no problems taking a few flights to make sure I don't ruin 80 hours of work!
Old 04-20-2008 | 06:18 PM
OK fair enough. I still think you should use all the controls in the first flight but JMO. If the engine quits and you can't make the field the gear better be up or there will be some major repairs. Would you leave the flaps alone too, especially on a warbird?
Old 04-20-2008 | 07:54 PM
gboulton's Avatar
My Feedback: (15)
*chuckle*
Man, you can't let ANYONE around here know that you're about to maiden something without eleventy-nine posts questioning your choices and/or abilities. )
Come on, guys...manks asked about "tradition" or "superstition", not prop selection and maiden advice. *heh*
Manks...since you'll not be the one flying it, I suggest this:
Take pictures before, DURING, and after.
Old 04-20-2008 | 08:03 PM
vegas mossie's Avatar
never take a picture of a plane before it flies, bad joo joo. its not a plane until AFTER it has flown at least once. don't mess with the r/c gods ( wind, gravity, ect.)
Old 04-20-2008 | 10:15 PM
TexasAirBoss's Avatar
My Feedback: (22)
Take "before" and "after" pics. Hopefully they will look the same.
Old 04-20-2008 | 10:37 PM
I dont take pictures, wear the same underwear that I have always worn for the last maidens (not washing it of course), dont shave, have my lucky rabits foot in my pocket, break a stick of balsa above the airplane (makes the rc Gods happy) sacrifice a live chicken and eat a bowl of lucky charms before I head to the air field. Also slice open your finger and put a drop of blood somewhere inside the plane when you have finished building it.
All kidding aside... Take lots of pictures before durring and after.. My daughter helps me with my planes so I try to take her when I can. Pack some drinks and snacks for after.. and I enjoy a nice cigar when I complet a succesfull maiden..
Old 04-21-2008 | 01:27 AM
I'm not supersticious, so I photo all of it. I fly it, use all of it's accessories, I enjoy my 15 to 20 minutes, then I land it. Time for another photo or two. Adjust Refuel, BS with the guys, fly again.
Old 04-21-2008 | 01:50 AM
YUKONFLYR's Avatar
Pics before and after[sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
