RCU Forums - View Single Post - GST 7.7 pullstart
Old 04-21-2008 | 06:23 PM
slawhammer
Default RE: GST 7.7 pullstart
Ok It came from 2 different hobby shop owners..In different towns..But I asked them if they have any CEN Products ..The Answer was no...
To make a long story short..Each owner said it just would be better if you had 2 gal of fuel ran thru your engine...With the engine
being tight from pinch..and for the piston to wear with the sleeve...It is common to do for most engines...Quote of 2 different hobby shop
owners...I just said until you have a cen products and have did some checking about cen.Maybe your wrong..That is way I said that..I know
as you have read also a lot of owners are having issues with the roto start being installed too so..As you also are a Cen owner...
So if there is some confusion on this ..Then less get this stright when a owner should install a roto start for these big engines..
