RE: DL-50 engine
Chuck, I turn on the choke and give it 1/4 throttle, then flip the prop back and forth between the start of the compression stroke to the other side of the compression stroke that primes the carb. The crank shaft has to go around bottom dead center, back and forth, back and forth about 10 times or so.
