RE: Scratch building 105" W/S Super connie L-1049 G
I like you guys to see the track and slider that i designed for this set up as my final design, i am not sure it i posted these images in past posts but here it is once again.
This is single slotted track and 2 guiding pin slider that travels in the slot. Image shows movement of slider in the track.
When i designed it, i made small added section on the L/E of the slider so i could attach linkages to it but now after seeing how George did his, i will most likely be modifying that
frontal added section of the slider. I will be posting more pictures of this wooden mock up in the flap bay for you to get better idea.
