RCU Forums - View Single Post - Jet Cat turbien mount - offset ?
Old 04-24-2008 | 06:01 AM
Aero65's Avatar
Aero65
Default RE: Jet Cat turbien mount - offset ?
Im not sure if this is correct or not.
But I beleive it was so you could directly retrofit a Ramtec fan powered aircraft with a Jetcat turbine. The Ramtec fans mounts were not on the center line but raised a bit. Unlike the Dynamax which was on the center line of the fan.
