RE: BEC
The specs on that ESC say "BEC: 5V/ 2A max". That means the throttle lead will supply 5 volts to the receiver. This is enough for most, but not all receivers. The disclaimer is because I know of several receivers that need 6 volts to operate properly. And you're right, just plug that into the throttle channel.
