RE: Exponencial on Throtle
Yes a gasoline engine powers up right after low throttle,sometimes you can be at 60% power with just 3 clicks.Add the expo..you can test the results on the ground.
Also on your servo horn,if you go to a closer hole to center,you will get less travel and be less sensitive.
