RCU Forums - View Single Post - Exponencial on Throtle
Old 04-25-2008 | 02:19 PM
Gulliver
Default RE: Exponencial on Throtle
The 9C has a mix called "THrottle Needle" which provides a 5-point curve for just this purpose. You can set the curve to give you a relatively flat spot at the hoverpoint so maintining the hover will be much less throttle sensitive.
