RCU Forums - View Single Post - MGT Engine
Thread: MGT Engine
Old 04-25-2008 | 03:24 PM
snowbl!nd's Avatar
snowbl!nd
Default RE: MGT Engine
You'll need a different manifold, and if you go for the matching LST manifold you'll need to grind some material from the bottom of it which is easy enough.
There is a rear exhaust maifold availible which will allow you to keep the pipe at the rear, i'm using that setup at the moment and it's a lot less hastle that mounting the pipe at the side and having to bend the manifold around the starter mechanism as well as hacking the plastic chassis guards.
