RCU Forums - View Single Post - CMPro Lancair
Old 04-25-2008 | 03:30 PM
  #279
linkadrip's Avatar
linkadrip
Default RE: CMPro Lancair
My lancair died all electronics removed from plane and engine. Will post pics later. Whatever you do make sure you have a good running engine this plane has no glide Ratio and mine dead sticked and hit the ground nose first. For the most part the plane is intact. Good bye to the lancair. i wont be rebuilding this plane. Oncew a plane is gone its time to move on.. Good luck with yours..[&o]
For the most part it still looks like a plane but all the internal wood was destroyed in the front and some in the back. A large hole is in the wing inside the fuse. I'm gonna patch it up try and make it look good again and hang it. My first Plane i nosed into tthe ground. And if someone shows intrest in it. and has the fiberglassing repair abilities that wants to take onthe challenge of repiring in i'll sell it to them cheap.lol
I myself dont have the know how on repiring fiberglass plus the would have to make all the wood components that go in the front that hold the tank and throttle servo and such.
ID:	936829   Click image for larger version
ID:	936830   Click image for larger version
ID:	936831   Click image for larger version
