RE: Sig Kougar Build
I worked my setup a little with more bench testing and some prop tweaking my numbers are:
968 - 980 watts (depends on a weaker 15C battery or not) drawing 68A, 78 oz of static thrust, BLV 13.43 on a worked 14"x12" APCE. I do run a seperate BEC. All stuff from HobbyCity.
I can turn and burn with it. But I usually fly at 50% throttle and get 15 minutes out of the 5000Mah LiPo. My flying field is at 4700 ft.
