RE: Curare 20
That is a good question. I can't see why it wouldn't be - but then again...
Are those fixed gear, or retracts?
If you want to have a bit more vertical, you might consider using a 10x4 prop. I would imagine that top speed will be no problem with any prop you could use.
Ed Cregger
***I just saw where you were using MK retracts. Danged memory!
