RCU Forums - View Single Post - Motor and Gearbox Testing
Old 04-29-2008 | 01:00 PM
  #40
jakeand's Avatar
jakeand
Default RE: Motor and Gearbox Testing
Hi Simon!
Thx for the link!
“I have a problem with you 'no load' torque”
Yes me too…but the only way for me to compare
“surely this should be 0”
Not 100% sure about that. If Torque 0, Amps/Watts also 0 ?
“And your torque should me in newtons per unit length, so what is your unit length?”
Yep, using this: Watt / (Rpm / 702,3)=Ncm (Value 702,This value is maybe not 100% correct)
“Also why 5.5v not 7.2v”
As Swath stated, voltage cut by El-Mod for Tiger settings
“Finlay since these motors are quite weak, you would of been better to measure RPM with a strobe”
Yes, but with Motor+Gearbox, measuring at the drivesprocket is no problem
“When I measured these motors I found they were repeatable in volts to RPM, the so called 'K' factor”
Yes, used Volt/rpm konstant for calculated values (rpm at 5,5 volts)
“but the stall current was difficult to repeat, due to heating and phase position”
Stall current is just a second before things begin to go up in smoke…I think its better to load/brake the motor under control….
Its Time to build a Dynamometer!
“This is why I have not published them”
Feel free to publish your findings, you are with friends![)]
This was my way to compare different motor/gearbox setups, a combination of measured real values and calculated values. The method is a bit simplified, e.g. motor efficiency, gearbox efficiency, rpm when loaded.
Not 100% perfect, but give you a hint what you could expect.
Best regards
Jake
